Yamaha Engine....Teleflex Gauges
  • Yamaha Engine....Teleflex Gauges
    Since I am using Teleflex and not Yamaha gauges; should I have ordered the yamaha engine insert and tubing part as recommended in my previous post response?
    I understand that there is a basic incompatibility of metric vs. standard english sizing.
    Would I do better to use the teleflex system direct from the guages to the engine and then adapt using: TEL 61886P by: Teleflex ?
    Am I correct that there will be no way to adapt from the Yamaha tubing at the gauge itself?
    Please advise...Thanks.
    No if you are using aftermarket then get the 6Y5-83553-N0-00 gauge harness(you will change connectors at gauges) and order MAR-WPRES-AD-TR water pressure adapter(will thread into block). Do not use Yamaha 688-83667-00-00 w/p tubing, use the Teleflex tubing.
      water & oil pressure senders
      I have the same issue to which I will use your advice that you have given but my question is finding the location on block to where each sender goes in. Secondly, I have a water temp gauge instead so which one is better to have or have both?
        If you are using aftermarket temp gauge then use their temp sender, it will probably bolt on not thread into port like Yamaha's.
          Thanks, and it seems that the thread-on sender would be the better one?..... Also does this harness "6Y5-83553-N0-00 gauge harness" work on my '86 115ETLJ
            Yes that harness will work. Yamaha temp sender may not be compatable with a non Yamaha gauge.
