The tilt motor is bad on our motor. I cannot get the valve relief screw to turn and the head of it is all stripped now. Is there another way to release pressure on the tilt cylinder so I can tilt the motor up? I can't get the tilt motor off unless I can get the outboard up.
Or is there another tool (other than the assortment of flat blade screwdrivers I have) that can be used to turn that relief screw. It's got a very wide slot, but there's not enough room in the side of the bracket to get a fat screwdriver through there.
THanks,
DB
THanks,
DB
