My motor has a problem. No water comes out of the tube under the head when the engine is hot. I have visually checked all areas for water flow(intakes, and chamber where thermostat is), changed the impeller even though the old one looked functional, and changed the thermostat. I also took the thermostat out and blew air through the tube that water is supposed to come out of. I think that the internal cooling passages are blocked?? It had been run in salt water before I got it. I am trying to make it work properly. Any suggestions on how to verify this or check that they are clear, and how to clear them if they are plugged?
Thanks for any help.
Bill
Bill
