What should be the minimum compression on a '99 v200tlrx ox66 before considering a rebuild. I'm showing 100-103 across the board. Did the compression cold w/ throttle open and closed. Also did it w/ engine warm w/ throttle open and closed. All readings were the same. If it's time for a rebuild where is the best place to get the parts for the best price. Thanks, stiver
Minimum compression
compression ?
I owned a 250 ox66 that had 95 psi on one cyl. and other 5 were 100to 103psi. It was the best running and starting motor I ever owned. I ran for a couple years expecting it to blow because a yam mechanic said it would. It never did ? I sold it on ebay for $1,825.00 and bought a 2003 250 hpdi with 115 to 120 psi on all cylinders that I also expect to blow up at any moment because of hpdi reputation.It has 2,457 hrs and I paid $2,200. for it. for that LOW PRICE I expect Kaboom?
