Trim Tilt just stopped working. It worked on and off for a couple days but then just stopped. I took off wires and re-connected, tapped with a rubber mallet, checked fuses, checked fluid I think (I don't know if I was looking at the right thing). Any help is appreciated.
Trim Tilt 2004 ftlrd115
Probably a bad trim motor then. REMOVE the trim motors wires from relay and connect trim motor wires to a 12 volt battery(Do not jump wires on relay, can damage relay) to see if motor runs.
The part number is 68V-43880-01-00, look at number 28 in diagram for price
Yamaha Outboard Parts 2005 F115TLRD POWER TRIM & TILT ASSEMBLY 2 Diagram
Do I have to replace the whole assembly or is it typically one part # that goes bad? Thanks for all your help.
ÂÂÂÂÂÂÂ
