I have a 98 90hp yamaha and I was haveing problems with it and found out it was the diaphran in the fuel pump so i changed it out. And should if been back on the water, but after thatthe motor seem to be running kind of funny thought the plugs my be bad so i change them and still same problem like it running on half the motor or something. Anybody with any ideals on what the problem may be.
98 90hp yamaha
Originally posted by jb123 View Posthave you changed water separator, checked motor filter for water ?
try using an auxillary tank hose and ball hooked to motor filter to isolate the motor from supply side.
chris
Originally posted by Aleutianwest View PostHow long was it running with a bad diaphram it could have wash the clyinders out Check Compression
thanks
chris
