Is there a seal for the lower unit prop shaft? I have noticed recently that there is oil on the skeg below my prop and thought there might be a seal on the prop shaft that needed to be replaced. If so do you have a part number and how hard is it to replace?? BTY I have a 2000 130 HP. Thanks
Lower unit leaking
Yes the propshaft takes 2 seals they are both the same. You have to remove the bearing carrier to replace them.
http://www.boats.net/parts/search/Ya...NG%20DRIVE%201
/parts.html
Number 63 in the diagram. Its best to pressure test it and verify the leak. Psi test at 7-10lbs, submerse in water is easiest way to find the leak. Look for the bubbles.
Good luck.
Ok thanks. Does the pressure from the prop nut and washers seal these 2 seals. I just changed props and thats when I noticed it leaking. Also concerning the pressure test to do it should I just look at the prop area while the motor is running out of gear in the water? NOt sure of the pressure test you recommend. Thanks
