I have a multifunction digital tachometer (PN 6Y5-2818R-32) that I am installing on a 2004 yamaha 60HP (F60TLRC) outboard which is connected by a Yamaha control box (#703). I need to know what wires need to be connected to properly install the multigunction digital tachometer.
Wiring is per below:
Control box (Yamaha #703)
harness 1 (green, yellow, black, red wires)
GREEN wire appears to go back through the harness to the motor and connects to the regulator and lighting coil.
YELLOW wire goes to the overheat warning buzzer and to the main switch and connects to the motor's "prime start".
BLACK wire goes to the emergency stop switch, to the main switch and through the harness to the motor's ground.
RED wire goes to the main switch, power trim and tilt switch and through the harness to the motor to the +12V.
Harness 2 and 3 at the control box (green, blue, red wires)
GREEN and RED wires same as above.
BLUE wire goes to the main switch.
Digital tach multimeter (PN 6Y5-2818R-32)
The wiring on the multimeter is as follows:
3 sets of wires
SET 1 (BLUE,GREEN, BLACK, YELLOW)
SET 2 (PINK, ORANGE,GRAY, BLACK WITH WHITE TRACER)
SET 3 (PINK, GRAY, GREEN WITH WHITE TRACER, GREEN WITH A RED TRACER)
I also need to know what the dip switch settings should be on the Digital tach multimeter and the basic function of the set and mode switches on the bezel.
SW 1 = Trim sensor type (2 or 3 lead)
SW 2 = Generator type (6 pole or 12 pole)
SW 3 = Engine type (4 stroke)
Any help would be greatly appreciated.
Paul
3 sets of wires
Paul
