Repower
  • Repower
    Hello,this Is My First Time In The Forum, So ,i Want To Repower My Boat (world Cat 26,6 Ft 98),i Want To Put 225hp Yamaha Four Stroke,(06-08),but I Not Know The # Of The Main Wiring Harness ,and What Are The Comand Link Square I Need For This Motor, Thanks
    Yanko.
    Main harness are available in 16,20,26, and 31 ft.
    6X3-8258A-00-00 16ft
    6X3-8258a-10-00 20ft
    6K1-8258a-40-00 26ft
    61B-8258A-01-00 31ft
    Command Link gauge kits come in 1 gauge kit or 2 gauge kit
    6Y8-WE83S-70-00 Square Tach kit
    6Y8-WE83S-10-00 Square Tach and Speedo/Fuel management kit
    You will also need 1 Main Bus wire and 1 Pigtail Bus wire per gauge(see list for lengths)
    Command Link Gauges and Bus wires
      repower
      hello,again,because my boat are cat it have two fuel tank,and need two tach,and two meter assy(speed& fuel mgt),tell me if right,and somebody say me that need a sensor speed kit ,this is correct?
      thanks a lot
      yanko.
        6Y8-WE83S-30-00 Square 3 gauge kit, 2 tachs, Speedo/fuel gauge
        6Y8-WE83S-20-00 Square 4 gauge kit, 2 tachs, Speedo, Fuel management gauge
        These kits come with Dual Binnacle controls, dual switch panel, main harness and speed sensor.
          repower
          hello.sorry the problem are that I was buying and have binnacle controls and dual switch panel,two tachs and speedo and fuel management,what more i need,thanks very,very,very much
          yanko.
            You already have gauges? Are they Command Link gauges or Multifunction digital gauges? Are they kits or gauge only?
              repower
              yes, i have command link gauge, I need the code and diagram of instalation of the all wire,because I don't know what Ineed to buy,for two 225 yamaha 4 stroke,I have two tach 6y8-8350t-01-00,and two speed&fuel mgt combo 6y8-83500-01-00,I have two fuel tank in my world cat 26.6ft
              thanks again,yanko.
                You will have to use the Command Link dual key switch panel. This list of parts also need 1 pigtail bus wire per gauge and 1 main bus wire to go between boat transom hub and hub at console.
                QTY Part Number
                (1) 60V-8A4L1-01-00
                (3) 6Y8-81920-01-00
                (2) 6Y8-82521-51-00
                (1) 6Y8-82553-01-00
                (1) 6Y8-82570-01-00
                (2) 6Y8-82582-01-00
                (3) 6Y8-82582-11-00
                (1) 6Y8-83553-01-00
                (1) 6Y8-8356N-01-00
                (4) Pigtail Bus Wires(see first post for part numbers)
                (1) Main Bus Wire(see first post for part numbers)
                Command Link Dual Engine parts list
