Hello, I have a 1987 Yamaha 40LH that is giving me some trouble. At idle, the engine will push the boat. Anything above idle, the engine revs but no faster forward speed. Reverse works fine.
I took off the prop and with the engine off, and in forward drive, turned the prop shaft in the forward direction by hand.
It was fairly easy to turn by hand, but made a clicking noise in the lower unit as it rotated. Everyone keeps telling me prop, but I'm thinking it's the clutch dog or forward gear. Should the prop shaft even turn by hand when in gear????? It will not do this in reverse.
What are your thoughts?
