F115 water5 pressure control valve
  • F115 water5 pressure control valve
    if i'm not mistaken this is the water pressure control valve for the 2002 F115
    p/n 6G5-12416-00-00
    i was wondering weather it would be a good idea to disassemble this valve every year or two? The reason i ask this is i have seen on other forums concerning larger Yamaha engines where this valve that they refer to as the poppet valve needs to be cleaned every so often to maintain or correct proper water pressure due to the accumilation of sand etc unseating valve.
    2002 ranger 175vs yamaha 115 hp fourstroke
    education is what you get when you read the fine print...experience is what you get when you don't
    Yes that is the pressure control valve and should be cleaned when doing a water pump replacement along with thermostats.
