I have a T 9.9 GEXH and would like to remove the tiller handle to make it remote throttle and shift, and remote start. I know there is a remote kit available from Yamaha. I'm wondering how much work this is, where I would find the instructions. I would also like to change the electric start from the 10 pin harness to a 7 pin harness. I have the seven pin harness on my existing motor. Is this information available in a manual?
The remote conversion is not hard, look at diagram http://parts.yamaha-motor.com/partim...x?d=109050,2,0.
If you already have a control box make sure it has push to open throttle.
If you have a 703 control box and it is pull to open you change it 703-48207-17-10 push to open with 10 pin main harness.
Thats the only harness listed for the the T9.9G motors. The only 7 pin to 10 pin adapter(7 pin eng. to 10 pin controls) is backwards for what you need. You can change to a 10 pin main harness to key switch, 6X3-8258A-00-00 16ft.
