2001 F100 Lower Unit
  • 2001 F100 Lower Unit
    What other Yamaha models use this same lower unit?
    I will need the complete model number of your engine. F100???
    Changes in gear ratio's, driveshafts etc. come into play and may influence the answers.
    TMD
      The model number is F100TXRZ which is a 25" lower
      I will be converting it to a 20".So I need to know which 20" lowers will interchange even if I have to change the drive shaft.I'm also looking for interchange on the transom brackets.
        Hello,
        IF a 2000 model 225 Yamaha lower end fits your 100 I may be able to help. I have a 225 complete lower end. I will be putting it on ebay shortly if you are not interested.
        Thanx.
