I was replacing the gear lube this week when I noticed a leak around th shaft. When I replace the gear lube I have always pumped in from the bottom, and I loosen the top screw as far out as possible without removing it, I leave my screw driver on the screw while I pump the lube. I watch for it to spill out the top hole and and simply tighten when full. I know I'm supposed to remove the screw completely but its always been sufficient to simply loosen, its also real easy to reseal because you just a couple turns away. Well maybe this time I didnt have the screw out far enough so that lube could pass by it because when I saw the lube leaking around the shaft I pulled the screw out entirely and heard a little pfft (release of pressure). After I filled the gear case and cleaned up the leak at the propshaft I watched the shaft for an hour or so and it didnt leak anymore.
Are th seals ruined if this is in fact what happened? Are they ruined even if after I released the pressure there were no further leaks?
Tom
Tom
