I have a 2008 f90 adding lcd tach but dont now which wiring harness I need can anyone help. tack is Yamaha LCD Digital Multifunction TACH gauge meter
Wiring harness for a yamaha lcd tach
It requires
6Y5-83653-00-00 16ft Trim/Oil harness(6Y5-83653-10-00 if need 20ft harness)
6Y5-83553-N0-00 gauge harness
Gauge Harness
2008 f90 tjr
Gauge Harness
Tach settings for a F90 is
switch one- up position
switch 2- down position
switch 3- up position
wire colors code
ok on the back of the gauge there are 3 sets of wires a male plug with four wires pink orange grey and black white strip. then a female wire plug with pink graygreen and red and green and white. then 4 wires without a plug green yellow blue and black. do you know which set of wires run what on the gauge thanks for all your help.
The gauge harness 6Y5-83553-N0-00 powers up gauges, connect gauge harness to key switch matching colors red, yellow, green and black and connect other end of harness to gauge.
Ordered one, this is all i need its a four storke and a jet so the oil and trim are not need. This should give me the tech reading and hour meter correct.
Thanks again for all your help
wires
ok recieved 6y5 83553n000 wiring. the end that goes to the gauge is ok i have blue to blue green to green yellow to yellow and black to black but i have 1 extra black wire. then on the other end i have a black green and yellow. if i hook up the green and yellow and black this will give me the tach and hour reading? it only has one fuseLast edited by 28shooter; 01-06-2009, 06:28 PM.
Connect both black wires from gauge to gauge harness black terminal and tach will work.
ÂÂÂÂÂÂÂÂÂÂ
