water tube going into water pump rotted
  • water tube going into water pump rotted
    hello just changed the water pump on my f 225 2003 when i checked the water tube the end going into the pump was rotted about a half inch just wondering how to change the tube my manual doesant cover that looking for ideas
    hello
    the only way to replace this tube is to take the power head off, and to take apart the mid section, and you will have access to this tube.
    frenchy
      thanks for the advice frenchy the rest of the tube seems fine filed the rough edges it loks like it goes in the pump about a inch and a half i think it might work ok? i will order a teck manual thats more detaild
        hello
        i temporary fixed one once with jb weld, just time to order and recieved the new tube, it worked fine .
        good luck
        frenchy
