Does anyone have the part number for the older style single engine switch panel, where the choke is operated from a separate switch (and not integrated with the ignition switch)? I've attached a picture of the 8-pin connector from my current panel.
As best I have been able to figure out, the newer style panel with the push-to-choke switch is part # 704-82570-08-00 ... and requires the newer harness (part # 688-8258A-50-00) with a 10-pin connector at the switch end.
I believe that the part # for the harness in my boat is 6X3-8258A-00-00, which has a 8-pin connector at the switch end.
Any help would be greatly appreciated!
