I have a 150 vmax that seems to have developed an intermitant problem of losing water pressure. I recentley had it serviced an impellor replaced, but in taking it out, it works fine and then for no reason (apparently) the psi drops. I can reduce rpmsto idle, then increase and the psi will come back up. Then run fine for awhile and drop. It seems I can tell when there is a problem because the psi will peg higher than normal for a short time before dropping. I use mostly in salt water and thought the sea grass may be clogging, but no other boats on the water seem to have the problem. Any ideas?
water pressure problem 150 vmax
Yes, I said the impeller was replaced because that's what the service ticket said. I have since called the service shop and they confirmed the water pump was replaced. I didn't realize the whole pump was replaced, I thought you could replace the impeller without the pump. Sorry to mislead. Service shop is stumped, any ideas?
ÂÂÂÂ
