Updating gauges
  • Updating gauges
    Need to replace my speedometer (6Y5-83500-A0-00) and they don't manufacture it anymore. What wire harness do I need and what is the replacement gauge that I can use?
    You can use 6Y5-83570-S5-00 speedo, it the same except for the overheat indicator light. The overheat indicator is in the Tach's now not the speedo.
      Great. I live overseas and I need to make sure that all is well with parts. Luckily I have a decent yamaha dealer. My next problem would have to be that they have a replacement tach and that makes me ask if that model, 6Y5-83500-00-00, has a temp reading. If not what is the replacement to get me up to date so all is well and I can take the old girl out and feel comfortable?
        That would require replacing the tach and which tach would depend on what year and model motor you have.
          '92 L250txrq.
            To replace tach on L250txrq you would need
            6Y5-8350T-82-00 Tach
            68F-82553-90-00 Trim/Oil harness
            61A-82541-00-00 adapter harness
