I'm in the process of rebuilding the carbs on my 70 hp 2 stroke, 2004 Yamaha. The screw that holds the float pin down (in place) will not loosen at all. I mean it will not budge. I stripped out the one on the top carb. So I decided to clean the bowls & jets thoroughly, and not try to make anything worse. Changed the gaskets & O-rings, and soaked all metal parks in Gunk.
I can't get to the parts under the float to change them.
Anybody else ever have this problem? What's the recommended method to get these screws to move? I just hate getting this far along & can't replace all of the rings, springs, & needle valves.
Any & all help would be greatly appreciated.
