charging system?
  • charging system?
    1996 130tlrt...confirmed good battery through pep boys charge and test machine,, voltage drops to 11.2-11.8 with enough run time to bring it above 12...lighting coil or rectifier-regulator ? or somthing else..??
    are your cables also 12 years old? if so they could be wick't...test volatge at batt, then switch,relay.
      I had the same problem. It was the regulator.
