yamaha multifunction tach switchover
  • yamaha multifunction tach switchover
    i have a 1993 yamaha with a digital multifunctional tach which has to be replaced. i would like to install the newer yamaha tach designed for engines after 1994. the wiring harness is different . is this possable and if so is there a wiring harness adapter made for this?????Thanks in advance..
    What model motor do you have?
      sorry;; it is a 1993 yamaha 225 txrr. there are two connectors on each tach with the 1993 tach( 0ld) having round and the newer one square. thanks....
        You would need
        6Y5-8350T-82-00 Multifunction Tach
        68F-82553-90-00 Trim/Oil Harness
        6N7-82541-00-00 Adapter harness,Eng
        6R3-82541-00-00 Adapter Harness,Eng
        Set tach setting for 12 pole alternator, 3 wire trim sender and 2 stroke engine.
