Cylinder head anode replacement - F200
  • Cylinder head anode replacement - F200
    Another job to do this fall check or replace the 4 cylinder head anodes on my F200. I have not tackled this myself before, but it looks fairly straightforward, as in:
    - remove anode assembly - single bolt offset from center of anode cover
    - unbolt the anode from the anode cover
    - replace anode and grommet on anode cover
    - reinstall assembly
    Any potential gotchas in the process? I am thinking to use anti-seize on the anode cover bolt where it goes into the head, but not on the bolt that holds the anode to the cover, to ensure a good electrical connection. Make sense?
    Tim
    They are easy to replace, don't use antiseize use grease.
      Thanks for your help.
