Hi. I'm not sure if I'm asking something stupid... I've been testing my new boat and there's always the same problem. The V4 2-stroke motor over revs 7200rpm with the tested props (26Pitch -> speed 65mph), gear ratio 2:1. After running some props with over 20% prop slip I thought that there must be something wrong with the revmeter. Is it be possible that meter shows wrong numbers at full speed? I had to start asking about this because I just saw that the rev limiter lead is connected in the CDI so it should not be possible to reach those numbers? I'm a bit confused about this - can the motor rev 7200 with the revmeter lead connected (I reckon no). Why is the revmeter showing 7200?
Thanks for advice.
Thanks for advice.
