Hi all, hoping to get a little help with rigging up a used engine I purchased for my sled.
1 - I'm using a 704 control box with teleflex cables. I purchased the teleflex cable ends and the cable was 1/2 inch short when in the engine cable clamp. Can't adjust any further with the cable jam nut. The teleflex connector is 1 inch long. Is the yamaha cable connector for this engine longer 6E5-48344 (say 1 1/2 inches)?
2 - I purchased the yamaha battery cable. It's not clear which terminals they connect to on the outboard.
3 - The fuel line is not included up to the fuel filter. Can I use any 3/8 inch fuel line? Do I need to include a primer bulb between the water seperator and the outboard?
Thanks for any help!
John
John
