Fuel issue
  • Fuel issue
    I have a 2005 115 4 stroke , it starts, idles, lit ruff , when put load on it, gives out, like its sucking air.? checked filter for water , checked in line filter, plug, ??
    Can someone tell me how to check file psi and what psi's I should have. I rigged up a gage but didn't work, at the top of the injection rail there is a vale steam like a car tire has. I'm guessing this is where I can check it?
    Should have 44 psi at schrader valve on VST.
      Is that at idle or check it while moving?? Is was cutting out last ya, just a little, I out new hose and bubble one it, thought it helped but didn't use it much, this year , it just bogs down when take off, runs OK slow ,but only had it kick in and take off for about a min. then bogged back down??
