I've been having problems with primer bulbs. They don't pump up hard, hold pressure and sometimes are just soft and squish-ey. I'm on #4. First three were Yamaha. last one aftermarket ???
Boat runs OK.---Starting has always been a problem though(Prime-Start Sys. Yuk-wish I had a simple push primer/choke)
What could be the problem?
I've tightened all fittings, replaced the fuel lines and connections My current replacement bulb seems to work great(hard and holds pressure).
Could it be just bad bulbs and the check valves not sealing properly.??
All seems too simple not to work properly.
