Hi folks, Great help here. I am having trouble with my 90. At times it starts and runs like a top. I will take it out drive a bit, then stop and swim and such in the lake. Then when I try to start it again there is nothing, no sound, no click, no nothing. A couple times I heard a click, would try again and then it would start. I assumed it was my starter on its way out but the next time it happened, I got towed to shore, I could also not trim up the engine. So it is clearly a power issue. The battery is strong, connections seem to be tight. After I fiddled with the manual trim screw to allow me to lift the engine by hand so I could trailer it out, I thought, hmmm wonder if it works, sure enough the trim worked and low and behold the engine started. This has happened 3 times now. The second two times all I did was paddle for 5 minutes, try again and then it worked. Like I said I checked the battery connections and everything is solid. What else should I look at?
Thanks in advance.
Thanks in advance.
