My 91 250 got some water in the #6 and got stuck from sitting. I pulled the head off and got her spinning again but need to find the source.
The heads were changed in the past and it and the gasket both looked good. I took the exhaust cover off and things look good there also. There is almost no salt in the motor and I checked closely with a flashlight and see no corrosion.
Before I put it back together does anyone have any ideas?
A friend said something about a lower crank seal. Is there a way to check that?
The plug was rusty but the top of the piston had no carbon on it.
