250 Seized from sitting
  • 250 Seized from sitting
    My 930 250 is stuck from sitting. It was running fine 2 months ago. I took the plugs out and put 2 stroke oil in the cylinders. What size nut is on the flywheel so I can try a socket and breaker bar?
    you MIGHT want to pull heads and see if there was any water intrusion from a head gasket. if you turn too hard you could possibly crack a ring...careful !
      I pulled the head and the #5 cylinder had some rust and salt in it. It didn't come from the head so maybe from the exhaust plate. Once I free up the motor I'll look further.
