1987 40 HP Yamaha Low Speed/Idle Problems
  • 1987 40 HP Yamaha Low Speed/Idle Problems
    At low speeds or when idling the engine will make a loud "chirping" sound and then die. Any ideas about where to start?
    Thanks,
    Chris
    I guess I would start by removing plugs and rotate by hand to see if a cylinder is not operating freely. Also compression check. Does it do it in gear only or idling in neutral also? I witnessed a mercury die in the same fashion, turned out to have a badly scored cylinder. (hopefully not the case).
      The chirp you hear will be from the crankcase. Check for fluid leaking around where the front and back of the case mate.
      TMD
