Volt meter hook up ?
  • Volt meter hook up ?
    I have a 2001 2 stroke 250 yammy and want to know if a analog dash mounted voltmeter gauge from a mercruiser v8 will work.I have the yamaha tach gauge with the hour meter.thanks
    Connect the yellow wire to the sender or + terminal on volt meter and the black wire to the neg.(-) terminal and it should work.
      Thank you
