Not sure how...but I blew the 10 amp fuse on the power connection (red wire inline fuse) to my speedometer. I replaced the fuse, but the guage isn't working. Any thoughts? Tach is still working fine.
Thanks,
LF
I forgot to mention the yellow wire, you should have 12 volts through yellow with key on. If you have power and ground and gauge doesn't come on then gauge is bad.
