i have a 200hp with carbs, ive been having alot of problems with this ,when i am taking off it seems to have the power for o few seconds then looses power but does not cut off,when i put it back to idle for afew seconds the power comes back then the same thing happens repeatedly, i changed the plugs changed the fuel lines change the fuel pumps and looked and clean the carbs please help.
200hp power lost
Sounds like it starving for fuel, pump the primer bulb when stalls to see if it trys to regain power.
power lost
i cleaned up a old set of carbs that came with the boat at work today,i put those on and she ran perfect . i noticed before i did this a couple of days ago the fuel lines from the fuel pumps to the carbs they all were callapse inside , i think pieces of the plastic went into those old carbs no matter how i clean them the problem was still there WHAT AN EXPERIENCE thanks
Loss of Power
I had a similar problem on the same engines and found that the connector rod between the oil pump and carbs had a plastic part that was broken on the end of the rod. This kept the opil from pumping to the engine and limited the RPMs until replaced.
ÂÂÂÂ
