ok, i have a 1989 yamaha 15hp. it got to where it would die when i turned it down to idle, so i bought a carb kit for it. cleaned it out good, replaced all gaskets and it still dies when turned down to idle. checked compression which was 120psi in both cylinders, replaced plugs and still the same thing. do you think i need to take the carb apart again and clean once more? im stumped.
Engine Trouble Please Help
