I have 2 questions.
1) Does the impeller have to be changed periodically if I'm not having any problems? I can't find it in the manual maintenance schedule but most people seem to think it has to be changed periodically.
2) How do I open the bottom unit to get to the impeller. I took off the propeller assembly and unlinked the control shaft and took off the lower unit nuts, as per the manual, but I can't get the lower unit off, no matter how hard I pull. Is there a special tool or technique ?
thanks very much.
thanks very much.
