Last week I ran my 2003 40hp 4 stroke for the first time since last fall. It was ran in a barrel and I noticed the p-hole did not stream water. I bought an impeller and today I removed the 7 bolts (including the one under the anode) and tried to remove the lower unit. I didn't know how to disconnect the shift linkage and tried to remove the camnut and locknut. The camnut would only turn down so far and then it stopped. Then my son said the p-hole was clogged and sure enough it was. We never got the lower unit removed more than an inch due to the shift linkage and we just tried to put the camnut and locknut back to their original position then we bolted up the lower unti and tried it. Of course the water pump did work but now a new problem: it shifts fine into forward and neutral but it won't shift into reverse. I took the shift cable off and tried to put the level under the carb back by hand and it won't budge.
I believe somehow I got something back together incorrectly as I did not put the shifter into neutral and the gearcase probably wasn't either.
I need to know how to remove the shift linkage and get everything lined back up (and I still plan on installing the new impeller as a preventative measure). Does it disconnect up in fromt of the powerhead where it starts down into the shaft? or was I doing something wrong when I tried to disconnect it at the adjustment camnut?
Help!
Help!
