no power - 2006 50 hp 4stroke
  • no power - 2006 50 hp 4stroke
    engine always maintained tip top
    always starts first out
    ran perfect last week
    this week - no power to engine! but power to stereo and horn.
    visually checked all fuses and connections, all appear ok.
    charged battery, swapped out battery with another charged battery
    engine and power trim are dead
    what do I look at next???? thanks
    No offense intended--are you sure it's in neutral?
      Thanks DM
      Everything appears as it should except no elec seems to be getting to the panel nor the engine from the main cables.
        Blown fuse on engine is the most common problem. Have run voltage test to see where loosing voltage.
          Thanks,
          We have checked all the fuses and they appear OK. I have heard that Yahmaha is having problems with battery cables on newer engines. That will be next with a line tester. Thanks everyone.
