low water pressure--89' ProV150
  • low water pressure--89' ProV150
    I noticed the water pressure was only at 10 psi yesterday at full throttle. At idle speed it will drop to 2 psi. I just put in a new impellar in the water pump and now it will get up to 15 psi at full throttle and drops to 2 at idle. Any help would be appreciated.
    Ron S
    is it overheating ? is this on the hose or in water ?
      Those are on the water readings. I don't know what the minimum readings should be, but I did notice that the tattle tale seemed to look weaker than in the past......it's still a steady stream just seemed to be less pressure. I'm worried that if I don't find out what's wrong, I could end up doing some damage running it with the lower pressure.
        no overheating yet.
          The mininum is 10 lbs at wide open and you wont get any reading at idle speed.
            Thanks much!! This is a great site for great motors.
              a couple years back I ordered parts......poppit valve was one of them. Didn't need it back then. Well, I decided to replace it yesterday.......the new design looked to be more efficient. My low water pressure problem disappeared.
