F250/lf250 / 2007
  • F250/lf250 / 2007
    boat.net,
    On 3/17/08 and 3/20/08 you gave me some info about connecting the wiring to the red wire of the regulator to install a second battery, using part #69J-81949-01-00. This wire is suppose to be laying in the engine pan but I can not find it. Before I remove the intake silencer, manifold, and fuse box , could you direct me to where this wire is?
    PS; Thanks for the info for the round command link gauges.
    freddy
    The wire is in front of the air box but is has a cover over the connector. It is a little to the left if you are facing the motor. You don't have to take the air box off to get to it.
      PJM or boat.net,
      I took another look , could this wire that is covered be in the wire harness with black tape? I did find a red #12 size wire ( hard to tell exact size du to limited visibility) coming out the right bottom of the fuse box directly under the 80 amp fuse terminal marked isolator, and the other end of this wire goes into the harness I described above. I just want to be sure prior to separating wires, fasteners , etc.
        I don't have a pic of the F250 but here is the F225.
