SX250Z Code Indication - Carbon Build up
  • SX250Z Code Indication - Carbon Build up
    Code indication on wink & blink – the code comes up 33 which is ignition timing is being slightly corrected (when stating a cold engine).
    So I have that code but what needs to be done to fix this problem.
    I am getting a lot of carbon build up, as I ***** at slow speed for 5 hours in the morning and then make a short run back to the dock and then do the same thing in the afternoon.
    The water has been about 45 to 53 degrees on top so I don’t know if the engines are getting hot enough to clean out some of the carbon build up. I do use Yamaha Ring Free and have started to clean the 02 sensor each year after replacing one.
    Check with your local dealers to see if they have tried changing thermostats or anything to account for the conditions in that area.
