2001 150TXRZ ignition/spark problem
  • 2001 150TXRZ ignition/spark problem
    Long story short.. the motor is running on 3 cylinders. Starboard bank 1,3 & 5 do not appear to be firing. Have changed out the spark plugs, moved the coil from #1 to #2 and the problem stayed with cylinder #1. Based on the advice of a mechanic I also replaced the CDI module but that didn't fix the problem either.
    Probably time to find a new mechanic, but now that the motor is 7 years old I am thinking that I will need to learn about it sometime. Any advice on the "brand" of repair or service manuals and troubleshooting ideas on the ignition problem would be greatly appreciated.
    Seloc or Clymer repair manuals will probably give you more information than the Yamaha service manual will.
