Hi!
I have a yamaha 225 Beto 6k7 UL 750849 1991 mod. Cant find similar engine-number at boats.net, but it seems to be the same as 225TLRP. It is an european engine, som maby that's the reason I can't find it.
My problem is that I can't get the automatic oilpump to work, I can manually activate the pump, but it won't start automaticly when the oil-level goes down. I have also connected 1999 mod. digital gauges to the engine, and these seems to no longer have info from the. oil level gauge. It shows low level, and the filler-icon is flashing. The alarm (and 1000 rpm limit) for low oil level works fine.
And yes.. I'm not american :P My english should have revealed that by now. You should hear me try speaking english I'm norwegian
