Hello!
I recently bought an Yamaha outboard motor in Brazil, the model is F20 BMHS, 4 stroke. I use the engine in small boats for fishing.
I recently purchased a rectifier and regulator, the parts number is 6AH-81960-00, which was correctly installed. Here begin my doubts:
1. I use the motor with small boats for fishing, and I do not will need a battery all the times. Can I use the motor with the rectifier connected to the motor, without a battery connected with the output of the rectifier? Or I need to disconnect the cables of the rectifier then, isolating it to the motor?
2. Can I use a hand light, connected directly to the output of rectifier, without using a battery?
Sorry for my poor english.
Thak you now.
Tomazelli
Thak you now.
Tomazelli
