The tilt switch on the helm panel drives the relay/motor for my 1985 V6 Special 220 but not the switch on the engine itself. Each switch is sending 12 volts up to the relays, but only one of the switches will actually make the relays work! To see if it makes any difference, I disconnected the 12 volt power input to the engine switch (which comes from another relay directly below the up and down relays) and connected it directly to the battery, but same result.
Please help. I'm stuck at this point.
