03 F225 fuel problem
  • 03 F225 fuel problem
    Hi,
    My F225 4 stroke cuts out at idle speed. It runs great on the throttles but at idle it cuts out and i have to prime the ball again, runs for a few minutes and cuts out again! It does this on both fuel lines (main and aux) and when switched over to other motors fuel lines. any ideas what is causing this?
    Need to have put on computer to have idle control valve and TPS checked, sync linkage on throttle body.
      The mechanic had computer on it, maybe he didn't check this systems. I have also been told it could be the vapor recovery kit????
        Figured it out! Changed the Vapor recovery kit and the motor is working fine. Apparently Yamaha cant keep up on demand for these kits so if anyone knows where I can get another, part#90891-40430 please let me know!
