lower unit oil bad?
  • lower unit oil bad?
    Hi.
    I replaced my lower unit oil and it came out looking like coffee with cream. I ran the motor for around 10 hours with the new oil and then changed it again. It came out basically looking the same. I put it in a mason jar and let it sit for about a week.
    For the first few days it seemed like there were white particles mixed into the oil. After 4 or 5 days the white particles have settled to the bottom and now the oil looks like this:
    It hasnt changed color, just the white particles have settled.
    Is my oil bad? Do I have a water leak?
    My local yamaha deal said that it was fine, but he didnt see it.
    I use the boat in high mountain lakes mostly over 6000'
    I also usually park the boat with the motor tilted because my driveway isnt flat.
    thanks,
    john
    could I use something like this?
    http://cgi.ebay.com/ebaymotors/Vacuu...QQcmdZViewItem
      maybe a dumb question but,
      Should I do the pressure test with the oil removed from the lower unit?
      -John
        What motor is it?
        Water contamination. What year and model motor is it? The common water entry points are the drain/vent plug gaskets and the driveshaft seal (located under the water-pump...). The drain/vent gaskets are easy to replace, but replacing the drive-shaft seal requires dropping the lower unit and removing the water-pump. The drive-shaft seal has a radius spring around the seal lip that likes to break, and this allows water under pressure from the water-pump cavity to work its way down the drive-shaft and into the lower unit in short order. The other seal entry point is the prop shaft seal located just where the prop-shaft exits the carrier housing. This seal gets damaged from fishing line wrapping around the prop-shaft. Its an easy fix as well. I assume you pulled the prop and inspected the shaft for any line or wire wrapped around it right? In any event you can discover these leaks during a pressure test. Just apply pressure and put some soapy water around these areas and you should see bubbles form up. Do you have a service manual for the motor?
        - Mike
          I swapped the plug gaskets when I changed the oil 2 times ago. So I dont think it was that.
          It is a 2004 F25
          I have not checked the prop shaft yet for fishing line
          I do have a service manual.
          I will do a compression test and check out the prop shaft tonight. Thanks!
            when i pressure tested today it leaked at 14psi (manual said to go to 14.2) assuming my gauge was accurate.
            I heard air leaking and the sound was coming from the water intake screens.
            The prop feels like its stuck and I am having trouble getting it off. I am having trouble getting the outside spacer off.
            Does it pull off, or screw off?
            thanks!
