Hi all
I am having problems connecting my Lowrance 522 IGPS to my Yamaha fuel management (FMM).
I have connected the yellow wire from the Lowrance NMEA 0183 port to the white wire on the FMM. All dip swithes are set correctly, but the FMM gets no signal from the Lowrance.
The lowrance manual displays the yellow wire (transmit) and the shield (ground) needs to be connected, but the Yamaha rigging manual says to connect ONLY the white wire ???
I have tried almost everything, but nothing helps.
Can any of you guys help me with the problem.
Martin
Martin
