1993 130 hp Oil system tests??
  • 1993 130 hp Oil system tests??
    Hi all,
    I have rigged and started my motor on the boat. Fired right up after sitting 2 years. I want to test the oil injection to see of all systems are GO. How does one do this. I have the motor running on mix now until I know things work. Initially I filled the main oil tank (1/3 full) and turned the key to on. Part of me thought it should fill the small engine tank. It did not so I did. The manual switch dosnt seem to do anything. Am I missing something?
    Right now my plan is to run on mix and then re-check fluid levels. Is there a better way to test for all systems Go?
    THANKS
    Opps sorry the motor is a 1994!!
    Oil should transfer from boat oil tank to engine oil tank with engine running or with emergency toggle switch. Check wire connections between engine and boat oil tank and eng. tank connections.
      JIT,
      Thanks again!
