i had an issues about a month ago with my yamaha pro-v 150 hp motor. there was a buzzer for the oil that went on i brought it back slowly to shore and filled it with oil. two weeks later i took it out to make sure it was all set and the noise sounded but then stop. so i figured all was fine. this morning i went out to prep the boat for fishing and noticed oil just behind the motor head had made a little pool maybe 1/4 or 1/2 a quart and there was also oil on the ground. the oil looks to be coming out from where all the wires and hoses go into the motor head. it seems to come out when the battery in hooked up. if i unplug the battery it slows and eventully stops. SOMEONE PLEASE TELL ME THIS IS NOT A CRACKED HEAD and tell me that it's the oil pump or something else.....
thanks
thanks
